quick question
BattlingMaxo
quick question
Post by BattlingMaxo » Fri Jul 06, 2012 11:34 pm
I am using 1.2.6 audacity and just got win 7 I installed audacity but it does not record. The mixer tool, where it should say what u hear or micorphone is grayed out. On my devices it shows micorsoft sound mapper for both input and output. What am i doing wrong? I could not see what i needed on the manual
BattlingMaxo
Re: quick question
Post by steve » Sat Jul 07, 2012 12:18 am
Audacity 1.2.6 is obsolete and no longer supported. It was written back in the days of Windows XP and was never intended for Windows 7.
Download Audacity 2.0 from here: http://audacityteam.org/download/
See also this tutorial to help you get started: http://manual.audacityteam.org/manual/h ... rding.html
BattlingMaxo
Re: quick question
Post by BattlingMaxo » Sat Jul 07, 2012 2:58 pm
New version works great
BattlingMaxo
