How to change pitch without creating echo?
Re: How to change pitch without creating echo?
Post by steve » Wed Jul 11, 2012 12:02 pm
Many sound cards on Windows have "Environmental Settings" that can add special effects to audio playback, ranging from a simple Equalizer effect, to "Grand Canyon Echo" and "Concert Sound" effects. Windows Media Player also has special effects, including their "Wow effect". Perhaps one or more of those effects were enabled and now turned off.
My previous comment still stands, "Sliding Time Scale/Pitch Shift" effect will produce a higher quality pitch shift effect, though it takes longer to process than the standard "Change Pitch" effect.
