mp3 weird problem
knuckles
Re: mp3 weird problem
Post by knuckles » Fri Jul 06, 2012 2:14 pm
Did everything you said all perfect works on my home system plays in windows media player and audacity.
Trebor
Post by Trebor » Fri Jul 06, 2012 6:56 pm
knuckles wrote:na i haven't inverted one of the tracks.
Maybe YouTube converts stereo to mono to save bandwidth in some display options ...
https://encrypted.google.com/search?q=y ... mono+sound
or only converts one channel on the video ...
http://superuser.com/questions/351249/f ... hannel-aud
knuckles
Post by knuckles » Fri Jul 06, 2012 8:13 pm
Is there no other way I can fix this problem?
Post by steve » Sat Jul 07, 2012 12:45 am
As we can't hear the file and cannot examine it, we can only guess at what the problem might be.
Do other files work correctly? Is it just this one song that has the problem? Where did this song come from?
knuckles
Post by knuckles » Sat Jul 07, 2012 12:05 pm
Yh other songs work perfect only this song and where it came from I recorded it at my friend house.
Post by steve » Sat Jul 07, 2012 1:12 pm
As an experiment, what happens if you convert the song to mono (Tracks menu > Stereo Track to Mono)?
knuckles
Post by knuckles » Sat Jul 07, 2012 8:23 pm
When I put it in mono it blanks out I get no vocals just the beat
Post by steve » Sat Jul 07, 2012 9:02 pm
Then your vocals have inverted phase in one channel.
Do you still have a multi-track copy with the vocals on a separate track from the beat?
knuckles
Post by knuckles » Sun Jul 08, 2012 10:19 am
No I don't think so how do I check if I do have one or not?
PGA
Post by PGA » Sun Jul 08, 2012 10:52 am
@knuckles,
Did you ever do a "File > Save Project" or "File > Save Project As" whilst working on this song? If so, you need to find the .aup file that Audacity created and open that file into Audacity. If you never did either of those then you almost certainly don't have the necessary multi-track file that Steve mentioned.
