mp3 weird problem
knuckles
mp3 weird problem
Post by knuckles » Thu Jul 05, 2012 8:43 pm
Hello guys what a wondeful site got a major problem I recorded a song at my friends house when I play it on my computer from audacity or my home system. It works fine but when I move the mp3 file of the song on my phone and I uploaded it on youtube the first verse vocals blanked out and only the beat was playing and the hook on the song came out and when I was talking on the end of the track that came out weirdly enough and when I play it through the headphone it works fine and I can hear all the lyrics is there something I can do on audacity to fix this problem. Many thanks
Re: mp3 weird problem
Post by kozikowski » Thu Jul 05, 2012 9:32 pm
Where is it so we can listen?
knuckles
Post by knuckles » Thu Jul 05, 2012 9:39 pm
I took it off youtube do you want me to send you the mp3?
Post by kozikowski » Thu Jul 05, 2012 10:33 pm
We're only good for tiny files on the forum.
http://forum.audacityteam.org/viewtopic ... 49&t=64936
knuckles
Post by knuckles » Thu Jul 05, 2012 11:08 pm
Damn what ur email I would send it to you the Mp3
Trebor
Post by Trebor » Fri Jul 06, 2012 7:30 am
knuckles wrote:... when I move the mp3 file of the song on my phone and I uploaded it on youtube the first verse vocals blanked out and only the beat was playing and the hook on the song came out and when I was talking on the end of the track that came out
Sounds like you may have accidentally created a karaoke version : aka "centre pan removal" , aka "vocal removal", by inverting one of the stereo tracks.
knuckles
Post by knuckles » Fri Jul 06, 2012 7:56 am
na i haven't inverted one of the tracks. As a test I did invert one of the tracks then my first verse came out, but then the beat was watered down and the hook came out then my talking at the end blanked out now. This is very weird lol it hurting my head I just want to know if there anything I can do to fix it on audactiy
knuckles
Post by knuckles » Fri Jul 06, 2012 10:53 am
Damn is there anyway I could fix this guys?
PGA
Post by PGA » Fri Jul 06, 2012 1:17 pm
You said in your original post that it plays fine in Audacity. Is this still true? If you export it as 16bit PCM WAV does that wav file playback OK in a media player (Windows Media Player for example)? If the WAV file plays back OK in a media player, export an MP3 file and try playing that in a media player. Does that play back OK? Do not use your phone or Youtube in all this. Just use your home system. The object of this to find out at what point the apparent corruption first makes its appearance.
knuckles
Post by knuckles » Fri Jul 06, 2012 1:37 pm
I'm try what you said and I let you know what happens
