Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Mon Aug 13, 2012 11:54 pm
mdubin wrote:Just did two tests with bug_557p3. The first one was successful with no quality issues. But the 2nd one crashed, and this time, it was not at the end but shortly after starting the process.
OK, thanks for letting us know.
Can you do your next two tests with "audacity_bug_557_revert_11858p1.exe" ? I expect that will probably crash at the end, but let's see.
mdubin
Post
by mdubin » Wed Aug 15, 2012 2:07 pm
Gale Andrews wrote:mdubin wrote:Just did two tests with bug_557p3. The first one was successful with no quality issues. But the 2nd one crashed, and this time, it was not at the end but shortly after starting the process.
Gale:
I did one test last night with audacity_bug_557_revert_11858p1.exe and there were no issues. It completed successfully and the quality was fine. I'll try to do another one or two this evening.
mdubin
- Quality Assurance
Post
by Gale Andrews » Thu Aug 16, 2012 5:40 am
Clayton has made a fix "bug_557_p4" that retains the fixes in "bug_557p3" for the crash at end of processing, but attempts to fix the new crash at the start. Could you download that and try it:
http://gaclrecords.org.uk/bugs/audacity_bug_557_p4.zip ?
If it crashes, then please tell us where in the processing it crashes, and continue testing with "audacity_bug_557_revert_11858p1.exe" (which I understand has completed once without quality issues).
Thanks again,
mdubin
Post
by mdubin » Thu Aug 16, 2012 9:13 pm
Gale Andrews wrote:Clayton has made a fix "bug_557_p4" that retains the fixes in "bug_557p3" for the crash at end of processing, but attempts to fix the new crash at the start. Could you download that and try it:
Thanks again,
I just did another test with audacity_bug_557_revert_11858p1.exe and it did not crash.
I will try bug_557_p4 when I have the time, either today or tomorrow.
mdubin
mdubin
Post
by mdubin » Sun Aug 19, 2012 1:04 pm
I did eight sliding time scale/pitch shift tests this morning with bug_557_p4.
None of them crashed and there were no quality issues. Good News!
mdubin
- Quality Assurance
Post
by Gale Andrews » Sun Aug 19, 2012 11:45 pm
Thanks! Good news indeed.
mdubin
Post
by mdubin » Wed Aug 22, 2012 12:46 am
I'll continue to use bug_557_p4.exe for sliding time scale/pitch shift only and my regular 2.0.1 executable for everything else.
Please keep me informed as to when bug_557_p4 will be incorporated into a future audacity release.
Thanks.
mdubin
- Quality Assurance
Post
by Gale Andrews » Wed Aug 22, 2012 1:13 am
mdubin wrote:Please keep me informed as to when bug_557_p4 will be incorporated into a future audacity release.
We are at rc4 for 2.0.2 - see
http://forum.audacityteam.org/viewtopic ... 46&t=67279 . 2.0.2 rc4 includes the "bug_557_p4" Time Scale fix. We aim to release rc4 as 2.0.2 in a couple of days if no major problems are reported with it.
mdubin
Post
by mdubin » Fri Aug 24, 2012 6:43 pm
Gale Andrews wrote:mdubin wrote:Please keep me informed as to when bug_557_p4 will be incorporated into a future audacity release.
Hi Gale:
I installed 2.0.2 today and did one sliding time scale/pitch shift test. It was fine. No crashes or quality issues. Will do some more testing over the weekend and report here. I do not expect any problems.
mdubin
mdubin
Post
by mdubin » Sun Aug 26, 2012 10:00 am
Hi everyone:
I did another four sliding time scale/pitch shift tests yesterday with 2.0.2 and, again, there were no crashes or quality issues.
Thanks for all your excellent support to finally get this issue resolved for Windows XP.
So I added "Solved" to the title of this thread.
mdubin
