Cannot select ASIO input
voralpen
Post by voralpen » Mon Jul 02, 2012 10:58 pm
Hi. I've recently bought a USB interface for connecting my guitar to the PC and use amp simulators (Amplitube and similar) "live". I'd like to record with audacity, but, when I select "preference" and "audio I/O" it does not show any trace of the ASIO driver. Any idea? Thank You for your help.
Re: Cannot select ASIO input
Post by kozikowski » Tue Jul 03, 2012 12:44 am
Audacity as it comes from the "factory" doesn't support ASIO.
Post by steve » Tue Jul 03, 2012 4:20 am
More information: http://wiki.audacityteam.org/wiki/ASIO_Audio_Interface
Are there Windows (WDM) drivers available for your device?
voralpen
Post by voralpen » Tue Jul 03, 2012 9:10 am
I'll check it out. Thank you very much for the quick reply!
