Inserting MP3 timed track breaks automatically.
Can I insert zero-length track breaks every three minutes automatically into a 4 hour MP3 audiobook file? I don't care where in the text the breaks occur, I just want to be able to create short tracks so I can navigate easily through the book, but I don't want to have to manually insert hundreds of track breaks. Sorry if this is answered somewhere, but if it is I couldn't find it. Thanks.
Re: Inserting MP3 timed track breaks automatically.
Use "Regular Interval Labels" (Analyze menu) to add labels where you want the "splits" to be, then use "Export Multiple" to export each labelled section as a separate file.
See also: http://manual.audacityteam.org/man/Spli ... ate_tracks
