That effect is going to be perfect!
thanks VERY much
now i have 135 effects - is there a manual on what the heck they do AND how to do it!
1. Amplify...
2. Auto Duck...
3. BassBoost
4. Change Pitch...
5. Change Speed...
6. Change Tempo...
7. Click Removal...
8. Compressor...
9. Echo...
10. Equalization...
11. Fade In
12. Fade Out
13. Invert
14. Leveller...
15. Noise Removal...
16. Normalize...
17. Nyquist Prompt...
18. Phaser...
19. Repair
20. Repeat..
21. Reverse
22. Sliding Time Scale..Pitch Shift...
23. Truncate Silence...
24. 4 x 4 pole allpass...
25. Aliasing..
26. Allpass delay line, cubic splint interpolation...
27. Allpass delay line, linear interpolation...
28. Allpass delay line. noninterpolating
29. AM pitchshifter..
30. Artificial latency...
31. Audio Divider (Suboctave Generator)..
32. Auto phaser...
33. Barrys Satan Maximiser,..
34. Bode frequency shifter (CV)...
35. Bode frequency shifter...
36. Chebyshev distortion...
37. Clip Fix...
38. Comb delay line, cubic splint interpolation...
39. Comb delay line linear interpolation...
40. Comb delay line noninterpolating...
41. Comb Filter...
42. Comb Splitter...
43. Constant Signal Generator...
44. Cross Fade In
45. Cross Fade Out
46. Crossfade (4 outs)...
47. Crossfade...
48. Crossover distortion..
49. DC Offset Remover
50. Decimator...
51. Declipper
52. Delay...
53. DeIayorama
54. Diode Processor...
55. Di EQ (mono)...
56. Di EQ...
57. Di flanger...
58. Dyson compressor
59. Exponential signal decay...
60. Fast Lookahead limiter...
61. Fast overdrive...
62. Flanger...
63. Foldover distortion…
64. Fractionally Addresed Delay Line…
65. Frequency tracker...
66. Gate...
67. Giant flange...
68. Glame Bandpass Analog Filter,.
69. Glame Bandpass Filter...
70. GLAME Buttenvocth Highpass...
71. GLAME Butterwoith Lowpass...
72. Glame Butterwcrth X-over Filter...
73. Glame Highpass Filter...
74. Glame Lovpass Filter...
75. Gong beater...
76. Gong model..
77. GVerb.,.
78. Hard Limiter...
79. Harmonic generator...
80. High Pass Filter...
81. Higher Quality Pitch Scaler...
82. Hilbert transformer
83. Impulse convolver...
84. Inverter
85. Karaoke...
86. L/C/R Delay,..
87. LFO Phaser...
88. Low Pass Filter...
89. LS Filter...
90. Mags Notch Filter...
91. Matrix Spatialiser...
92. Matrix: MS to Stereo...
93. Matrix: Stereo to MS
94. Modulatable delay...
95. Mono to Stereo splitter
96. Multiband EQ...
97. Multivoice Chorus...
98. Notch Filter...
99. Pitch Scaler...
100. Plate reverb...
101. Pointer cast distortion...
102. Rate shifter...
103. Retro Flanger…
104. Reverse Delay (5s max)…
105. Ringmod with LFO...
106. Ringmod with two inputs.
107. SC1…
108. SC2…
109. SC3…
110. SC4 mono…
111. SC4…
112. SE4…
113. Signal sifter...
114. Simple amplifier...
115. Simple delay line cubic spline interpolation...
116. Simple delay line, linear interpolation...
117. Simple delay line, noninterpolating...
118. Single band parametric...
119. Sinus wavewrapper...
120. Smooth Decimator,..
121. State Variable Filter..
122. Step Demuxer...
123. Surround matrix encoder
124. Tape Delay Simulation...
125. Transient mangler...
126. Tremolo...
127. Triple band parametric with shelves...
128. Valve rectifier...
129. Valve saturation...
130. Vocal Remover (for center-panned vocals)...
131. Vocoder...
132. VyNil (Vinyl Effect)...
133. Wave shaper...
134. Wave Terrain Oscillator
135. z-1
attenuate the drum beats?
Re: attenuate the drum beats?
A note. We urge people not to back up a large truck (lorry) and dump ton lots of effects, plugins and filter into Audacity. One sure way to kill Audacity out of the gate is to load an effect it can't handle.
"See that huge pile of effects? One of them is bad. Have a happy day."
That and Audacity, unless you prevent it, tries to do an index of all your software and you could be there until next Thursday waiting for it to go down the list and manage everything it finds.
thanks all
The pack of LADSPA effects has been put together by Steve Harris.
There is a limited amount of information about each of those effects on his web-site. Unfortunately his website appears to be down at the moment, but here's the address: http://plugin.org.uk/
