Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
TRgthe2nd
Post
by TRgthe2nd » Wed Jun 27, 2012 2:16 pm
Audacity 2.0.0
Windows XP x64 SP3
I am trying to make the same changes to multiple audio files without doing each one manually.
I downloaded mp3 files and I am trying to get it in the right format.
I need to change the "Project rate" to "8000" "Split Track to Mono" and "Export to .wav", this I know how to do. What I need to know is if I can set it to do this without doing this without going through every single song (Over 200 songs
and I'm going to get more, The question is do you want to do all that manually
). Anyway please reply fast and detailed so I can follow you (this is the only reason I downloaded Audacity and don't know how to use it well so help me please).
- Site Admin
Post
by steve » Wed Jun 27, 2012 2:55 pm
Unfortunately Audacity cannot do that as a "batch" operation, though I think there are ways to accomplish the task a lot more quickly than doing one at a time.
TRgthe2nd wrote:I need to change the "Project rate" to "8000" "Split Track to Mono" and "Export to .wav",
If you split a stereo track to mono you end up with two tracks. Is that what you want? Do you then want to export 2 mono files from each stereo input file?
