I installed the old 1.3.13 version last year...I never used it...Should I uninstall it before installing Audacity 2.0 ?
Thank you....I run Windows 7......
Installing New 2.0 Version Question
Re: Installing New 2.0 Version Question
It's probably best to uninstall the old version first - saves confusion later on
Thank you Steve...
