My partner is trying to record speech for a presentation she's planning to do. She's working on multiple stereo tracks in Audacity, with one of those being speech. She's already recorded the first section, but whilst trying to record the second - which she was doing on a separate track in a new file, to be inserted into the master project later - she found the resultant recording very muffled and very quiet.
The odd thing is that on reloading the original project we've now found that that speech track is also playing back equally quiet and muffled. It was playing back fine, but something's changed and we can't work out what it might be.
Immediate suggestions we thought of:
Microphone. We're not using a quality mike. In fact, it's a fairly flimsy, simple one with a standard 3.5 jack. We're not after exceptional recording quality and the one we're using is adequate. We've tested using another mike (a cheap headset) and the effect is the same, so we think we can rule out a mike and/or speakers fault.
Sound card. Actually there isn't one: we're using integrated Realtek sound. Again, we're aware this isn't high quality, but it's adequate for our needs. We're reasonably sure it's not the cause of the problem since Windows sounds and MP3s etc play perfectly normally.
Realtek settings. There is a graphic equaliser/environment settings program installed, which we thought might be having some sort of impact but we've checked it and made sure all the distortion effects and so on are switched off.
We've tested the mike in Windows Sound and the visual indicator suggests it's picking up all right.
And then we get to Audacity itself - but I'm afraid I'm no expert and I don't really know what settings to look for. It's always just worked before. So I wondered if any of you would be able to provide me a checklist of some of the basic settings needed to do what we want to do?
If it helps, we're using Audacity 2.0.0 on Windows XP Home, version 2002, Service Pack 3. The machine has a 3GHz CPU and 3GB RAM (somehow). To be honest I can't remember whether Audacity came from the .exe or the .zip.
We're really just looking to see if there's anything obvious to look for that might have changed in the meantime - some people say computers don't just reconfigure themselves, but personally I've never believed that.
Thanks for reading, and for any suggestions you might be able to offer.
Tac.
