Side by side configuration?
bebo1192
Post by bebo1192 » Sat Jun 23, 2012 5:12 am
I have succesfully downloaded and installed audacity, but when ever I try to open the program an error message pops up and says " The Application has failed to start because it has a side by side configuration error. I am trying to open this on a windows vista.
Re: Side by side configuration?
Post by Gale Andrews » Sun Jun 24, 2012 3:01 am
bebo1192 wrote:I have succesfully downloaded and installed audacity, but when ever I try to open the program an error message pops up and says " The Application has failed to start because it has a side by side configuration error.
Are you using Audacity 2.0.0 from http://audacityteam.org/download/windows ? If not, please download that version.
Otherwise please try the steps in the green panel here:
http://manual.audacityteam.org/help/man ... html#probs .
