Audacity with LAME
dballinger
Audacity with LAME
I need help getting my LAME program to work with my Audacity.
- Quality Assurance
Re: Audacity with LAME
A good place to start is the Frequently Asked Questions .
If you are still stuck after that, tell us where in the instructions it is going wrong.
