Launch Audacity from Command Line into Auto-Record Mode
Is it possible to launch Audacity from the command line into an Auto-Record Mode?
Re: Launch Audacity from Command Line into Auto-Record Mode
I don't think Audacity does anything from the command line, but we'll see what the other elves think.
Okay. I was hoping there would be a command line switch like /R to start recording
