Creating Batch
rarekind
Re: Creating Batch
Post by rarekind » Sun Jun 17, 2012 2:06 pm
Problem solved!
It halted on one certain file... the reason why is unknow to me, because when I did this file seperatly it worked flawlessly.
Any way...
I now have all my files exported to the desired file extension.
Thank you for you help.
Regards, R.
PGA
Re: Creating Batch
Post by PGA » Sun Jun 17, 2012 2:39 pm
steve wrote:Did you try it?
No! In my use of Audacity I have no need of chains. As I said, I was merely enquiring out of curiosity. Your answer is good enough to satisfy that curiosity.
