Creating Batch
rarekind
Creating Batch
Post by rarekind » Fri Jun 15, 2012 4:31 pm
Hello everyone,
What I want is a shortcut of audacity which has a code that I can drop any audio track on and puts the speed adjustment effect on it. (not the tempo effect)
Or
A batchfile which I can put in the directory and output for all the files in that specific folder. (With the same effect)
Does anybody knows how to do this?
With kind regards.
[Moderator Note: Please stop editing this file. Each time it is opened for editing it gets flagged up for moderation which is a waste of time]
Re: Creating Batch
Post by steve » Fri Jun 15, 2012 4:36 pm
Batch processing support in Audacity is described in the manual here: http://manual.audacityteam.org/manual/h ... pply_chain
rarekind
Re: Creating Batch
Post by rarekind » Fri Jun 15, 2012 4:50 pm
Wow!
Thanks a ton!
It works... I'm so happy!
Thank you again! YES!!!!
rarekind
Re: Creating Batch
Post by rarekind » Sat Jun 16, 2012 10:56 am
I did the chain option...
Only got a problem with it.
Audacity does not do all the files in the folder (mp3 / wav)
Even when I check the "all files"
Regards.
Re: Creating Batch
Post by steve » Sat Jun 16, 2012 12:09 pm
Did you actually "select" all of the files?
Anything special about the ones that were missed? For example, are they all of a particular type/format?
rarekind
Re: Creating Batch
Post by rarekind » Sat Jun 16, 2012 2:13 pm
I did select all and they are only wav's and mp3's...
it is a batch of 1424 files.
I also see that audacity skipped non capital files...
It's still going on...
I will post more info when it's ready!
This time I only did the wav's
rarekind
Re: Creating Batch
Post by rarekind » Sat Jun 16, 2012 3:52 pm
wav's are ready. and audacity did them all.
the non capitals were done after the tracks with capitals...
on to the mp3's
keep this thread posted...
any insight appreciated
Re: Creating Batch
Post by steve » Sat Jun 16, 2012 4:37 pm
Be careful if you have mp3's and WAV's with the same file name.
If you have a file: bladebla.mp3 and a file bladebla.wav and the chain tries to export them both, you will have a file name conflict - I've not tested but I'd not be surprised if the first one to be processed was overwritten by the second.
PGA
Re: Creating Batch
Post by PGA » Sat Jun 16, 2012 5:36 pm
I'm butting in here with a question just out of curiosity: how would a chain handle the "File already exists, do you want to over-write" dialogue box that would occur when running under Windows and trying to save using a filename that is already present in the destination folder? My understanding (probably flawed) is that chains are built of unconditional logic only, or am I wrong?
Re: Creating Batch
Post by steve » Sun Jun 17, 2012 11:08 am
PGA wrote:how would a chain handle the "File already exists, do you want to over-write" dialogue box that would occur when running under Windows and trying to save using a filename that is already present in the destination folder? My understanding (probably flawed) is that chains are built of unconditional logic only, or am I wrong?
Did you try it?
On Linux, files with the same name are overwritten without error or confirmation (which is probably more useful than stalling an unattended batch processing job). I presume that the behaviour is the same on other platforms.
