Hi, really new to this and not a techno!
Need to do voice recording with music in background and have managed this but voicesounds like poor quality recording, underwater kind of noise, on and off, and goes bassy at times, is there an effect I can use to clean up voice quality?
Voice recording not clear
Re: Voice recording not clear
My guess is that you are recording using the in-built microphone and sound card on your Windows 7 laptop computer and it sounds rubbish?
Hi Steve, no its a pc and using a usb headphone/microphone by Trust
Topic moved to the Windows forum.
Which version of Windows?
Windows XP
Do you have Skype running in the background?
Could you post a short sample for us to hear (see here for how to post a sample: http://forum.audacityteam.org/viewtopic ... 49&t=64936 )
