hey guys
I tried both 2.0 and also 1.3 beta... it is the same error when i load the program.. installing it was fine
"this application has failed to start because the application configuration is incorrect" I got windows XP SP 3. any ideas? i have tried to uninstall it and nothing.
Windows Application Configuration error?
darcytranc
- Quality Assurance
Re: Windows Application Configuration error?
Please see:darcytranc wrote:hey guys
http://manual.audacityteam.org/help/man ... html#probs .
