lost recording
kklein
lost recording
Post by kklein » Fri Jun 08, 2012 12:19 am
i was recording a speaker. ended recording and hit the wrong button. was asked if i wanted to save changes.
i clicked no (which i usually do when modifying other recordings - it's kinda automatic).
All my recording data disappeared. Can it be recovered?
Re: lost recording
Post by steve » Fri Jun 08, 2012 1:50 am
Did you save the recording in any way at any point?
kklein
Re: lost recording
Post by kklein » Sat Jun 09, 2012 4:48 pm
regretfully, no. The wave screen blanked out after i clicked "no"...k
Re: lost recording
Post by steve » Mon Jun 11, 2012 8:06 am
It's probably too late now, but if Audacity has not been closed since deleting the track it is usually possible to use "Edit > Undo". However, I don't know what you pressed that lead up to the "Save Changes" prompt. If Audacity has been closed then the recording is gone and lost forever.
