MP3 files are only buzzing sounds
rollinmoss
Post by rollinmoss » Mon Jun 04, 2012 12:07 am
I can use Audacity to record and play files as Audacity files, and Audacity appears to export these files as MP3 files, but when I try to play them using Itunes or Windows Media Player, I get only a buzzing noise, like the sound you hear when you test the Tone on Audacity. I'm using Windows 7 and downloaded Audacity as an exe file.
Re: MP3 files are only buzzing sounds
Post by kozikowski » Mon Jun 04, 2012 2:51 am
You just missed saying where the music came from. Is this you singing and playing the guitar into a microphone?
PGA
Post by PGA » Mon Jun 04, 2012 7:21 am
What output device do you use to listen to the sounds in Audacity? What output device do the other media players use for their playback? If these are not the same, that could be the source of your problem.
rollinmoss
Post by rollinmoss » Tue Jun 05, 2012 9:36 pm
I am recording music from a cassette tape onto my laptop and listening to the results on my laptop. The Audacity file sounds fine on my laptop, but the mp3 file is just a buzzing noise. I've never experienced this in listening to other mp3 files on my laptop, and I've not attempted to transfer this mp3 file to another device to try to listen to it there.
