Uploading Wave File To Cox Business Auto Assistant
dyorke71080
Post by dyorke71080 » Sun Jun 03, 2012 11:06 pm
Hello,
I am trying to upload a couple of wave files to my online Cox Communication Auto Assistant.
Cox will not let me upload becasue they say that my wave file needs to have the following characteristics:
Format: CCITT u-LAW
Attributes: 8.000 kHz, 8 Bit, Mono 7kb/sec
Can someone please tell me how to format my sound file so it exports with these settings?
Thank you!
Re: Uploading Wave File To Cox Business Auto Assistant
Post by kozikowski » Sun Jun 03, 2012 11:17 pm
You should probably install the FFMpeg software package from here...
And when you File > Export your show, choose "Custom FFMpeg Export" and then find your format in the listings.
Post by kozikowski » Sun Jun 03, 2012 11:20 pm
Oops. Sorry. You don't need that (although it handy to have). You can File > Export > Other Uncompressed Format and search for uLaw.
dyorke71080
Post by dyorke71080 » Sun Jun 03, 2012 11:52 pm
I see.
Thanks for the help!
