Making Ringtones
Making Ringtones
I have installed the latest Audacity 2.0 and LAME. Now I'd like to make my own ringtones. However, I get stuck when I try to export my file as an MP3. I get the metadata "box" and have to name THAT file. It confuses me. Could someone point me in the right direction?
Re: Making Ringtones
You can ignore the metadata box and just OK it. You can also set Audacity to stop showing you the box.
waxcylinder
this tutorial from the Audacity Manual may be useful to you: http://manual.audacityteam.org/man/Tuto ... _Ringtones
Thank you both for your information. One more question (I hope!!): How do I find out what format file is used on my phone? I have VerizonWireless as a provider and a Samsung Convoy 2 phone. I've tried VerizonWireless tech support but they haven't been able to provide me with an answer. Thanks.......
waxcylinder
I think you need to contact Samsung tech. support as the manufacturer of the hardware for that information.
Good idea - glad I thought of that
waxcylinder
Oops sorry - I wasn't reading right was I
You have my sympathies... I recently bought a Samsung TV an excellent TV, but their tech support I found underwhelming, particularly compared with the excellent tech support from Humax and Sony for the PVR and Blu-ray purchased at the same time.
waxcylinder
Looks like MP3 may work
See this external forum: http://www.howardforums.com/showthread. ... 640-Convoy
googling for "samsung convoy ringtones format gave me 219,000 other results so there's plenty to go at ...
http://www.google.co.uk/search?q=samsun ... NA_enGB284
maxmillion
there are some special apps to make ringtones but how do you make a song into a ringtone? if you making ringtones on your own try this site out [Link Removed] good luck!
There are hundreds of commercial ringtone sites and they are frequently the benefactor of forum spam so we do not allow advertising for any of them.maxmillion wrote:if you making ringtones on your own try this site out [Link Removed]
To keep this forum pleasant and useful for Audacity users we have a zero tolerance policy on spam.
