Missing frames
fpefpe
Missing frames
Post by fpefpe » Tue May 22, 2012 12:04 am
Hello -- Not sure were to start on this -- It seems that some of the frames from my ripping an LP are missing -- a fraction of a second -- is this a function of the hardware or the load of the os (xp 32 bit) giving audacity time-slices to run?
waxcylinder
Re: Missing frames
Post by waxcylinder » Tue May 22, 2012 1:07 pm
