Also - where you wrote :
As I previously wrote, this is covered in this tutorial: http://manual.audacityteam.org/manual/h ... ables.html
I have XP not windows7 or vista
RECORDING & SOUND WAVES
Re: RECORDING & SOUND WAVES
- Attachments
- AUDACITY3.JPG (80.1 KiB) Viewed 463 times
- Quality Assurance
What is the UAC 3556B device that is listed - is it a USB sound card that is connected to the computer? That does not look like the turntable which are usually called "USB Audio Codec".
As Windows does not seem to recognise the turntable, you should follow these instructions: http://wiki.audacityteam.org/wiki/USB_t ... ing_system .
If you see the turntable recognised in Windows but not in Audacity you can try Transport > Rescan Audio Devices in Audacity.
