Lost files
Re: Lost files
Bought a new computer and tried to install Audacity several times and it failed. It said create process failed code 14001 application configuration is incorrect. What does that mean and what can I do to get Aduacity up and running.
- Quality Assurance
Re: Lost files
Please see the green panel in this Frequently Asked Question .bniehuis wrote:Bought a new computer and tried to install Audacity several times and it failed. It said create process failed code 14001 application configuration is incorrect. What does that mean and what can I do to get Aduacity up and running.
