Cannot Get Audacity to Record
MrStokED
Post by MrStokED » Fri May 11, 2012 5:51 pm
OK, so I've been using Audacity for years and have never had this problem.
I just updated to the newest version because Audacity was crashing every two seconds and now I simply cannot record anything.
The VU meter shows no activity even though I never disconnect the mic. And I have it cranked up all of the way
When I click record, it doesn't. The red tracking arrow just blinks and remains in one space. It doesn't advance and there's no recording.
Very bizarre!
Please help!
Ed
Re: Cannot Get Audacity to Record
Post by kozikowski » Fri May 11, 2012 5:56 pm
You posted in a portion of the forum where we can't tell anything about you. We need to find out a lot more to diagnose the problem. Windows? Which one? Which Audacity? How much hard drive space do you have?
What kind of microphone and how do you have it connected?
That will give us a push. Please note that reinstalling Audacity doesn't reinstall Audacity, so one step at a time.
MrStokED
Post by MrStokED » Fri May 11, 2012 6:15 pm
Actually, I just fixed the problem. It seems all I had to do was unplug the mic and then plug it back in again. Then Windows detected it and all is good.
Post by kozikowski » Fri May 11, 2012 8:44 pm
So it was a USB microphone. It would have been good to know that.
gravelin1
Post by gravelin1 » Sat Jun 23, 2012 7:21 pm
I have the same problem only different. When I push pause and record, the input meter goes all the way over and it's in red. It doesn't record anything either. I just bought a new computer and it uses windows 7. I have been using xp and version 1.3.something and I've never had a problem before. any ideas?
PGA
Post by PGA » Sun Jun 24, 2012 5:47 am
Push Pause again to release the Pause?
yola
Post by yola » Sun Jun 24, 2012 4:54 pm
Hi
I have the problem that audacity does't record the audio cassettes (neither waveforms nor playback).
I use Windows7, Audacity 2, the cassette player is connected to the computer trough AD-320 USB. The same worked last week, but then I suppose the boy of a friend changed anything...
The prefrences are set as indicated and I couldn't find any solution in all the tutorials, faqs, etc. Recording via microphone works fine so I hope it's not a problem of the AD-320 USB (I bought it a few weeks ago and it worked till last week).
I'd be happy about any hints... Thanks in advance!
yola
Post by steve » Mon Jun 25, 2012 10:07 am
yola wrote:I have the problem that audacity does't record the audio cassettes (neither waveforms nor playback).
Please start a new topic on the forum board here: http://forum.audacityteam.org/viewforum.php?f=46
Please read this topic before posting: http://forum.audacityteam.org/viewtopic ... 49&t=63799
yola
Post by yola » Sun Jul 01, 2012 7:40 pm
ok - problem solven: it was this tiny tiny symbol for the input slider in the operating system mixer device that was off...
