I recorded vocals in my living room. They are very dry and need effects.
I cant figure out how to apply effects to the specific track (vocal) after the fact.
How does this work? Someone help me???
Thanks a ton!!
Chris
Vocal effects...
Re: Vocal effects...
To apply an effect you will need to "select" the audio that you wish to apply the effect to.
See here: http://manual.audacityteam.org/man/Audacity_Selection
