Problem with Input Device
laffen
Post by laffen » Sun Apr 22, 2012 12:14 pm
I want to record the sound that comes out of my speakers. In Windows Xp, I choosed Stereo Mix and it worked good. But when installing the program om my Windows 7 computer, I can't find this choice. In the manual I read that I can choose between Stereo out, Wave Out or Sum but I can't see any of the alternatives in Audacity. I have tested all the alternatives but none works. See attachment the alternatives. What to do? Image
Re: Problem with Input Device
Post by kozikowski » Sun Apr 22, 2012 12:25 pm
The latest version of Windows may be missing the tools you need to record internal sound or internet audio.
http://manual.audacityteam.org/help/man ... puter.html
