Recording issue please help!!!
Ok i have a numark mix track pro and i was trying to record a new mix i just made. so i pluge in my rca cable to 3.5 jack then pluged it into my line in componet on my computer. then i hit record and i pushed play on my numark mix track pro.Then i went to look at audacity to see of it was recording it was but it was really loud and distorted . Like the bars where so big it wouldn't fit onto the screen. does anybody know how to fix this???
Re: Recording issue please help!!!
If you have a laptop computer, then there's a really good chance you don't have a Stereo Line-In and Mic-In typically only works with actual microphones. Scroll down to "Connections."then pluged it into my line in componet
http://www.kozco.com/tech/audacity/wind ... rding.html
oh ok do u know any way i can get a mic in or something?
