trk 1 re-records on overdub
flwoods1
Post by flwoods1 » Sat Apr 21, 2012 7:38 pm
Hi,
Can't find similar problem, so plz excuse if I missed it. New to Audicity. I can record, but when trying to lay down a second track, first track re-records onto it as well as my input. Vista recording thru Behringer 302 USB, however mixer shouldnt be an issue, TY for any help
Re: trk 1 re-records on overdub
Post by kozikowski » Sun Apr 22, 2012 3:44 am
That typically happens if you like to record Internet Audio and leave that setting by accident. That will create recursive loop-back sound pathways and lead to your problem.
Regard the Device Toolbar and make sure you're recording from an actual physical Device or Sound Thing like microphone or USB Adapter, and not a made-up device like Mix-Out or Stereo-Mix.
http://manual.audacityteam.org/help/man ... olbar.html
flwoods1
Post by flwoods1 » Sun Apr 22, 2012 11:08 pm
TY, Problem solved. I was looping signal from my headphones back to new track.
