Newby set up help
Newby set up help
I have just downloaded Audacity and want to know how I can record what I play on my comp or from my imput via 3.5 jack. When opening up edit then preferrnce it does not have the options that are in the help menu
- Quality Assurance
Re: Newby set up help
Please see http://wiki.audacityteam.org/wiki/Mixer ... ssues#xpcp if you are on Windows XP or previous or http://wiki.audacityteam.org/wiki/Mixer ... es#vistacp if you are on Vista or 7.
If you need more help after that, please say exactly what version of Windows you are using.
