Windows 7, Audacity 2.0.
I record some sound from microphone, save it as MP3. I can playback this record in standard Windows software.
I can't playback it in Audacity even just after recording. Speakers are OK (default).
Maybe somebody can help me. Thanks a lot.
Boris K.
No playback[SOLVED]
- Quality Assurance
Re: No playback.
You can select "Speakers" or "Microsoft Sound Mapper - Output" or "Primary Sound Driver" in Device Toolbar.
Re: No playback[SOLVED]
Thanks Gale! I choose "Microsoft Sound Mapper - Output". Working!
Boris K.
Boris K.
