Keyboard shortcut for "paste?"
drumphil2
Post by drumphil2 » Wed Apr 18, 2012 5:31 am
I'm trying to create a click track for a track that wasn't originally recorded to a click so I'm going to do it manually. Was wondering if there might be a keyboard short cut for pasting? Would make this already tedious task a little less tedious:-)
PGA
Re: Keyboard shortcut for "paste?"
Post by PGA » Wed Apr 18, 2012 8:57 am
Try CTRL+V, that's the usual Paste command on a Windows PC. Also, take a look at Edit > Preferences > Keyboard in Audacity. That tells you all the default shortcuts.
Post by steve » Fri Apr 20, 2012 4:27 pm
