No sound when recording
Re: No sound when recording
Post by steve » Thu Apr 19, 2012 1:24 pm
Thanks for the summary, that has lifted the mist of confusion from my head ;)
(and you're using Windows 7 - that's important because of the weird way that it handles audio)
Let's start with getting your system sound restored to normal, then we can start again with enabling recording if you wish.
Try unplugging the jack to USB cable then reboot the computer and see if sound comes back (try playing a known-to-be-good audio file in Windows Media Player). Does that work?
paulpth1
Post by paulpth1 » Fri Apr 20, 2012 1:59 pm
Hi steve no it did't work I went into ITunes the song was playing but the sound is still got distortion and echo or delay
Post by steve » Fri Apr 20, 2012 2:53 pm
Check your sound card settings - you may have some "effects" enabled.
paulpth1
Post by paulpth1 » Fri Apr 20, 2012 6:24 pm
Hi steve I don' know how to do that and to reboot I just held the power button in and held it so I don' really know if that was right. I am not very technical with a computer
Post by steve » Fri Apr 20, 2012 7:03 pm
For the sound card settings, look near the time/date for a loudspeaker icon.
To reboot, the best way is to shut down completely, then restart. See here: http://windows.about.com/od/windowsforb ... ptions.htm
