No sound when recording
paulpth1
Post by paulpth1 » Mon Apr 16, 2012 12:49 pm
Hi I am using audasity 2.0 I import a backing track and can play it back and listen to it but when I plug my guitar in through a line 6 pocket pod using a jack to USB from the amp out to my computer and press record I have no sound either on the backing track or what I am recording.Can you help. I am using windows 7
Re: No sound when recording
Post by steve » Mon Apr 16, 2012 1:23 pm
As above:
Information about this forum
This board is ONLY for general feedback and discussion about Audacity 2.
If you require help, please post on the forum board relevant to your operating system.
This is not to be awkward. It's because we need to know what operating system you are using to be able to advise you correctly.
Post by steve » Mon Apr 16, 2012 1:49 pm
Topic moved to the Windows forum.
Check in the Windows mixer that the USB device is visible and enabled.
The quickest way to access the mixer is to right-click over the speaker icon in the System Tray > Recording Devices.
See here for some pictures: http://wiki.audacityteam.org/wiki/Mixer ... es#vistacp
After you have checked that the USB device is enabled, open Audacity.
In the Audacity Device Toolbar set the "Recording (Input) Device" and the "Playback (output) Device" to the USB option.
Plug your headphones into the line 6 pocket pod.
Adjust the headphone level.
paulpth1
no sound
Post by paulpth1 » Tue Apr 17, 2012 7:53 pm
Hi Steve still having trouble I have windows 7 and audasity 2.0.0 I want to record guitar along with a backing track through a line 6 pocket pod. I have a jack to usb from the pod. When I don't have the USB plugged in I can hear the backing track but when it's plugged in and I press record nothing will work so when I press stop I get a message about Latency correction has moved . I also tried not using the USB but a headphone jack out of the pod and into the headphone on computer.I I could record along with the backing track but I could not hear myself as I was playing but when I stopped and pressed play I could hear both even though my guitar was so much louder than the track. please can you help.I done all you said in the last e-mail but I am not that great with computers so I may have not done it to the letter.
Reason: post merged into topic
paulpth1
Post by paulpth1 » Wed Apr 18, 2012 9:07 am
Hi steve done what you said and all I have achieved is to muck the sound on my computer so I can't listen to any thing. All I am getting is distorted sound on everything can you tell me how to restore my sound before I had audasity as I would rather have a functioning computer than audasity
Post by steve » Wed Apr 18, 2012 3:50 pm
When a USB audio device is plugged in, Windows will use that as the default device for playback (whether the device is capable of audio playback or not!)
Unplug the line 6 pocket pod and reboot your computer. Windows should then revert to the normal sound card.
waxcylinder
Post by waxcylinder » Wed Apr 18, 2012 5:46 pm
or just reset the output device to be your on-board souncard with the Device Toolbar - see: http://manual.audacityteam.org/man/Device_Toolbar
Post by steve » Wed Apr 18, 2012 5:52 pm
waxcylinder wrote:or just reset the output device to be your on-board souncard with the Device Toolbar - see: http://manual.audacityteam.org/man/Device_Toolbar
That will only affect Audacity playback, it won't affect sound from other applications.
To enable the normal sound card for all applications you need to either unplug the USB device or change the default playback device in the Windows sound device settings (accessible through the Windows Control Panel or through the "Mixer" from right clicking on the speaker icon in the bottom right corner of the Desktop).
Re: no sound
Post by steve » Thu Apr 19, 2012 12:03 am
paulpth1 wrote:Hi Steve still having trouble I have windows 7 and audasity 2.0.0 I want to record guitar along with a backing track through a line 6 pocket pod. I have a jack to usb from the pod. When I don't have the USB plugged in I can hear the backing track but when it's plugged in and I press record nothing will work so when I press stop I get a message about Latency correction has moved . I also tried not using the USB but a headphone jack out of the pod and into the headphone on computer.I I could record along with the backing track but I could not hear myself as I was playing but when I stopped and pressed play I could hear both even though my guitar was so much louder than the track. please can you help.I done all you said in the last e-mail but I am not that great with computers so I may have not done it to the letter.
To post a reply, please click on the "POST REPLY" button. I just found this post all on its lonesome on a different forum board.
What is this "jack to usb from the pod"?
I've just looked up the Pocket Pod - I was assuming from your first post that it was a USB audio interface, but now I see that it is just an effect unit and the USB connection on it is for editing its settings. So you are using some sort of "Jack to USB" cable as the actual "audio device"?
If that's right then that arrangement will not allow you to hear the backing and the live guitar at the same time.
I've got a bit confused about the current situation as the posts have got out of order.
Could you give a description of the current situation - probably best to describe in full as if none of the previous posts had been written - let's start afresh with this.
paulpth1
Post by paulpth1 » Thu Apr 19, 2012 8:47 am
Hi Steve the situation is I am trying to help my son post himself on you tube.I import a backing track and tried to record through the direct out/phones into the mic on my PC.This did't work so I brought a jack to USB so I had guitar input into the pod and amp out of the pod to the PC via the USB connection, this did't work and I could only play back the backing track if I removed the USB.At this time I contacted yourself and tried to follow your instructions and all I have done is somehow mucked the sound on my PC ie when I try to play anything with audio the sound is very distorted with an echo or delay. All I want now is to restore my PC and maybe give up on Audasity as a bad job
