Audacity GPF on start up
fpefpe
Post by fpefpe » Wed Apr 11, 2012 1:24 am
Hello --
upgrading to 2.0 might fix this issue -- But here is the problem. I am running v 1.2.6 on win/xp 32 bit. I have a few computers
running at the same time, so I do a remote access into the system I want to run on.
When I remote into XP, and start audacity, it gpf's - If I run it from the machine in question, it start fine -- any body
know what the problem could be?
Re: Audacity GPF on start up
Post by steve » Wed Apr 11, 2012 1:30 am
fpefpefpe wrote:upgrading to 2.0 might fix this issue
Perhaps you should try that. Audacity 1.2.x is obsolete and no longer supported.
