what should my computer settings be at?
carolmaccrone
Post by carolmaccrone » Tue Apr 10, 2012 5:24 pm
im using a samsung laptop to record from my cdjs throught the microphone port.what should my laptop settings be at.? aint a clue.. :?
PGA
Re: what should my computer settings be at?
Post by PGA » Tue Apr 10, 2012 7:44 pm
Hi,
You have two possible better options than using the microphone to capture the CDs.
Option 1 - Record from "Stereo Mix" (see this manual entry for how to set that up: http://manual.audacityteam.org/man/Tuto ... e_computer)
Option 2 - Use CD ripping software (Windows Media Player will do it) It will be quicker than capturing each track whilst it plays.
