Audacity installs in wrong language
diag
Post by diag » Sun Apr 08, 2012 2:55 pm
I use Windows7 64-bit installed in English. I installed from the .exe installer. I chose English as the installation language and in fact the installation dialog WAS in English. However, when I opened the program it appeared in French. I have tried reinstalling several times but problem repeated. I had no problem with two other installations I made on Linux and Vista 32-bit.
Re: Audacity installs in wrong language
Post by steve » Sun Apr 08, 2012 6:04 pm
See here for how to change the language: http://manual.audacityteam.org/man/FAQ: ... y#language
