Recording Problem
seni143
Recording Problem
Post by seni143 » Sun Apr 08, 2012 1:03 pm
Hello Audacity Staff/Programmer
I've a very strange problem with Audacity!
I've this version: Audacity ® 2.0.0 (Unicode)
When I use Sound Recorder of Windows which is in it by default, then microphone works fine, I use skype it works fine there as well, but when i open audacity, Microphone stops working until i log off pc! Its very strange + some times it disables the PC voice as well!
I'm wanting to record some thing in my voice and audacity isn't helping me out!
Please help me, thanks
Re: Recording Problem
Post by steve » Sun Apr 08, 2012 6:22 pm
seni143 wrote:When I use Sound Recorder of Windows which is in it by default, then microphone works fine
Which Microphone?
seni143
Post by seni143 » Mon Apr 09, 2012 1:38 pm
please explain what do you want to ask?
Microphone Company or?
its Minghai H-450 Head Phone (including microphone to talk)
Post by steve » Mon Apr 09, 2012 4:42 pm
I'm trying to get a picture of what you are trying to do and what equipment you are using.
So you have a combined headphone/microphone set plugged into the mic and headphone sockets of your Windows 7 laptop and you want to record yourself singing?
Please correct anything that I've guessed wrong.
seni143
Post by seni143 » Tue Apr 10, 2012 2:18 pm
I've a pc (Dell) and I'm using Windows XP
I want to record my voice using Audacity but microphone not working!, but when I close Audacity or log off PC, Sound gets record easily with Sound Recorder (which is by default in windows)
I hope I've cleared my problem 8->
seni143
Post by seni143 » Tue Apr 10, 2012 3:36 pm
Problem is fixed
I changed option of Recording from Preferences and its fixed!
thanks
