How can I sync my drum machine via midi/usb?
GothWeaver
Post by GothWeaver » Sun Apr 08, 2012 4:40 am
I'm looking to use the play/record/stop buttons on Audacity to control the play/stop on my drum machine. the drum machine can only interface via midi (5 pin). is there a special program or patch I'll be needing?
Re: How can I sync my drum machine via midi/usb?
Post by kozikowski » Sun Apr 08, 2012 4:46 am
Audacity does not speak MIDI. That's a Feature Request for a future version.
GothWeaver
Post by GothWeaver » Sun Apr 08, 2012 4:54 am
Is there an interface device that can convert Audacity's language to midi? I just need to send commands FROM Audacity TO the midi drum machine.
