Clean up static from wave file
fanewland
Post by fanewland » Fri Apr 06, 2012 4:28 pm
I am trying to use Audacity to clean up static on a wave file I have and having a difficult time doing this! Can you help me, or walk me through how to do this?
Re: Clean up static from wave file
Post by steve » Fri Apr 06, 2012 4:34 pm
What sort of "static"? If it's "distortion" due to recording too loud then it's probably not fixable.
Perhaps you could upload a short sample (2 or 3 seconds in WAV format) for us to look at. Below the forum composing message box there is an "Upload attachment" tab.
