I have the newest Audacity version and have discovered that I don't have precise control over the line that marks where to clip, insert silence, etc. It will not go exactly where I put the cursor and click. Instead, it seems to jump forward a bit. I never encountered this problem with previous versions. Can anyone help?
Thanks.
Setting cursor in recording
Re: Setting cursor in recording
Make sure that you do not have "Snap to" ticked (down at the bottom left).
Thanks! That did it. I can't tell you how much I appreciate the help.
