Have version 2.0.01 of Audacity (great program!) but when I try to export a file to
MP3 with Lame 3.9.9.5, I get a "This version of Lame is not compatible with this version
of Audacity" or some version of the same thing. What can I do?
CAN'T EXPORT TO MP3
Re: CAN'T EXPORT TO MP3
Tried to download Lame 3.9.9.3 and site was blocked by my antivirus program.
Found Lame version 3.99.2.3 works. Thanks for the help.
ZUG
ZUG
