Recording - no devices found
MusicBuffy
I have just updated Audacity to version 2.0.0 and now find that I am unable to record streaming from my sound card (Realtek). When I go into Preferences in Audacity I get 'No devices found' under Recording. I am using Windows Vista and have the latest sound card driver installed. Any help would be much appreciated. I had no issues with the 1.3 Beta version
Re: Recording - no devices found
On the same computer with the same operating system and the same sound card?MusicBuffy wrote:I had no issues with the 1.3 Beta version
Check that "Stereo Mix" is enabled on your computer (see here for details: http://wiki.audacityteam.org/wiki/Mixer ... es#vistacp )
MusicBuffy
Stereo mix wasn't enabled - great thanks for your help
