Recording from computer output
shikaku
Post by shikaku » Mon Apr 02, 2012 3:36 pm
I'm using Audacity 2.0 in XP Pro on a Dell Inspiron E1705 laptop with legacy audio drivers. I'm trying to use Audacity to record sound directly from the computer output--e.g., mp3 files. On my old Dell desktop I could do this with SoundForge, but neither SoundForge nor Audacity will do it on the laptop. I'm assuming the audio drivers aren't set up to do that. Can anyone help?
Thanks,
s.
Re: Recording from computer output
Post by kozikowski » Mon Apr 02, 2012 5:30 pm
Some newer Windows machines "leave out" the ability to do that.
http://manual.audacityteam.org/man/Tuto ... e_computer
Robert2
Post by Robert2 » Mon Apr 02, 2012 9:38 pm
Have a look at the following free software:
http://www.milosoftware.com/en/index.ph ... dleech.php
