Exporting Audio Files
SunshineNicki
Post by SunshineNicki » Sun Apr 01, 2012 7:19 pm
I am on Windows 7. Updated to the latest version and added the lame plug ins. I am recording audio off a record player for my grandfather. I do have clips saved in Audacity from the record player. Exported files into mp3 and wmv. When I play it in Windows Media Player I get dead air. What am I do wrong???
Re: Exporting Audio Files
Post by Gale Andrews » Mon Apr 02, 2012 12:48 am
If it's a USB turntable, just unplug it from the computer. See http://manual.audacityteam.org/help/man ... k.html#usb .
SunshineNicki
Post by SunshineNicki » Sun Apr 08, 2012 7:43 pm
Thank You. That helped. I appreciate it. I know my grandfather will love it!!!
