Unable to execute file
rpagett
Post by rpagett » Fri Mar 23, 2012 11:40 am
So I get this error after downloading and trying to run 2.0:
C:Program FilesAudacityaudacity.exe
This application has failed to start because the application configuration is incorrect. Reinstalling may fix this problem.
I have no idea to fix this. Can anyone help?
Thanks!
rpagett
Re: Unable to execute file
Post by steve » Fri Mar 23, 2012 4:39 pm
Which version of Windows? XP?
For 32-bit Windows XP, download Microsoft Visual C++ 2008 SP1 Redistributable Package (x86). Double-click on the downloaded "C:vcredist_x86.exe" file to run it and follow the instructions. If you are asked whether you want to uninstall or repair, choose "Repair".
For 64-bit version of Windows XP, please download instead Microsoft Visual C++ 2008 SP1 Redistributable Package (x64) then double-click on the downloaded "C:vcredist_x64.exe" file and follow the instructions as above.
rpagett
Post by rpagett » Sat Mar 24, 2012 12:40 am
Thanks Steve! Now I need to figure out how to get the audio to play while recording
Post by Gale Andrews » Sat Mar 24, 2012 4:10 am
rpagett wrote:Now I need to figure out how to get the audio to play while recording
Transport > Software Playthrough to listen to what you are recording.
Transport > Overdub to play existing tracks while recording a new one.
rpagett
Post by rpagett » Sat Mar 24, 2012 10:15 am
Thanks for the reply Steve! Now I am having problems with Audacity recognizing the audio playing./ Last night, I recorded side one of an Eric Clapton album. This am I tried to record the second side with no luck at all. The record line is straight while the input audio is indicator is definatly playing.
Any thoughts there? BTW, still cannot hear the playback as it records?
Post by steve » Sat Mar 24, 2012 11:52 am
rpagett wrote:BTW, still cannot hear the playback as it records?
See the previous post by Gale.
rpagett
Post by rpagett » Sat Mar 24, 2012 3:44 pm
Neither of those methods work for listening to the recording or even recording any sound, the line is still flat :(
Post by Gale Andrews » Sun Mar 25, 2012 2:10 am
rpagett wrote:Neither of those methods work for listening to the recording or even recording any sound, the line is still flat :(
If you want to listen while you are recording an LP then Transport > Software Playthrough is the correct choice, however if you are recording silence then software playthrough (which sends the input to the output with a delay) will also be silent.
If you need help reconfiguring Audacity please let us know how you are connecting the turntable to the computer and which audio indicator says that audio is playing.
