Hello,
Can Audacity 2 (Windows 2010; installed from .exe or zip) measure response latencies between a specified number or words recorded? In other words, can Audacity tell me (in miliseconds) how long it took a person to say a particular set of words or how much time elapsed between, say, two/three/four specified words that were recorded?
Measuring the speed of recorded words in a sentence
Re: Measuring the speed of recorded words in a sentence
Not automatically, but if you select the recorded words you can look at the numbers in the Selection Toolbar:
http://manual.audacityteam.org/man/Selection_Toolbar
Hi Steve,
Thank you for this. I will try it out. Problem is I might need units smaller than seconds.
Aviva
Aviva
Different "Selection Formats" are available. (e.g. hh:mm:ss + milliseconds)Soesman wrote: I might need units smaller than seconds.
See here: http://manual.audacityteam.org/man/Selection_Toolbar
