I use Windows Vista Business on my laptop and I downloaded audacity 2.x how ever when i try to make a backing track from mp3 files the wave patterns are missing... all i have is just a line...
Also when i tried recording my voice for a Japanese project.. the wave patterns were there for a milisecond then it became a straight line
HELP please
it is very urgent as my project is due tomorrow
Thanks
No wave patterns... HELP HELP!!!!!!!!!!!!!!!
apple_pepper
Re: No wave patterns... HELP HELP!!!!!!!!!!!!!!!
How exactly are you doing that?apple_pepper wrote:when i try to make a backing track from mp3
If you Import an audio file (File menu > Import > Audio)
then you should see the waveform appear.
Are you sure that the audio file really is an MP3 file?
Does the MP3 file play correctly in your media player?
apple_pepper
i did do thatsteve wrote:How exactly are you doing that?apple_pepper wrote:when i try to make a backing track from mp3
and the mp3 works in my media player
and im sure on that
But idk why the waveform isnt there
apple_pepper
it is a correct mp3 file
just that no wave patterns are showing up which is weird....
all my media players can play this mp3
