Audacity crashes everytime I try to open a previous project
ID10T_er
Post by ID10T_er » Wed Mar 21, 2012 8:26 pm
I saved it as a .aup file and everytime I try to reopen it inside audacity, audacity glitches, stereotypical windows 7 white screen program fail, and then I'm forced to shut the program down. Has anyone else experienced this? Am I doing something wrong? please halp, it was a large file (1hour and a half) and I would hate to have to rerecord it.
Re: Audacity crashes everytime I try to open a previous proj
Post by kozikowski » Wed Mar 21, 2012 10:58 pm
Does it fail to open if you close Audacity and double-click the aup file, or alternately, Right-Click > Open With > Audacity.
An hour long show isn't that big a deal (unless you have a really tight-for-space machine). I do that regularly at home.
Just to cover all the regular bases: You didn't try to move either the aup file or the _data folder, right? When you named the show, you didn't try to use dates or other punctuation marks? 20120321. That's today's date. Not 3/21/12.
